Galaxy Tab Pro 8.4: Battery Issues!
T Busby
83
So my tablet was at about 75% and I did some light gaming on it. I hadn't kept track of the percentage when playing, but I noticed the screen dimmed because it was running low on power after about 30-45 mins of use. It had under 15% battery left. I went ahead and restarted the tablet and guess what, the battery was at 54%! I do have a terrible charging pattern so it might need recalibrating. Any tips would be helpful.
Let it charge up overnight, then use it normally until it's down to maybe 10%, then charge it up fully again. Do this two or three times. Does it normalize afterwards? If not, the battery might be failing.
The battery life sucks on mine. I'm sending it in to hopefully get fixed!!
