Galaxy Watch Screen Brightness Issue
I've had the same problem... After trying a few things I found if I wake up the watch with a longish press on the home/power button it goes to the full brightness setting that I've set it at..
Try that
Hi. My watch just had a update. I think it may have cured this problem. Will try later when I find a dark spot.
Hello! Since the new software update earlier this week I am having a problem with my screen brightness setting which I have set at 8. When my watch goes into AOD mode, after the 15 second screen timeout, and then when the screen goes back on again the brightness setting is down to 3. Then I change it back to 8, the screen goes into AOD, and when the screen goes back on it is down to 3 again. Every time. Never had a problem like this before the recent software update, or on my Gear S3 for years. I turned the watch off for a few hours, and then turned it back on, but the problem persists. Has anyone else had this problem, or know how to fix it? Thanks!!!
Mine is too, I had to set at the highest setting and so I checked and it was at like 4, so I reset it again and within a couple of minutes it went back to 4 and brightness. Yes I recently updated a couple days ago.
Hi. I have been dealing with this AOD brightness changing issue for a while after firmware update Nov 2021. Both with GW active2 and Galaxywatch3. The new Update for GalaxyWatch3... (probably the last Tizon update for these models, just came out 8-14-2022. and it also DID NOT fix this issue. I have not tried to reset watch yet again...I will try it.... but I am going to call Samsung one more time to see if I can get any fix. Frustrating. It doesn't seem to bother some people and there are many threads about the issue. I'll check back.
achongpius2022
