GB update, then return OEM battery issues
anon(255332)
46
After the GB update last week I noticed my battery life was so much better I decided to return to the Stock battery after using the extended battery since the 2nd day of having the phone.
Now it seems my TB is running just a bit slower than before. Is it just me, am I crazy, or did the extra battery power also mean extra processing power.
Any one else had similar issues?
-Tm
-Tm
I also put the stock back in and it runs smooth and quick.
Don't be crazy!
There is no way the extended battery was making your phone faster.
Unless you had some odd CPU profiles set so that when your battery is at a self determined low the CPU clocks down. (This is assuming the extended would reach this determined low slower/less than the OEM).
But short answer- You're crazy. :confused:
tuananh3105
