Gear Fit2 - water resistance
Delirious D
776
Can i shower with my fit2?
i have the s2 which is also supposed to be water resistance, but i wont even wash dishes with it on.
I've been in the pool with my S2 and have had no issues whatsoever and I've showered with the Fit2 and same thing.
I haven't chosen to do so, as I take that opportunity to take it off and wipe it down. Also a good time to wash that part of my forearm. :)
Technically, the Fit 2 is designed to work at a depth of 5ft for 30 minutes.
So, given that, you should be OK.
I been taking mine off except hand washing. Its should be ok for a shower or swim though.
sukarisw22
