Gear S: Has it reached any solution to be fully compatible with iphone?
fransis1976
5
I bought a gear s with it's tizen "closed" os more than 2 years ago. Used it 3 max 4 times cause the not full compatibility with my iphone.
I red that now there a stable workaround to make it fully compatible and working installing android wear, but not sure.
Does anyone know a stable solution to fix this problem? Or i have to try it out from the window?
Sorry about that I read where it said you can download for gear S and took that as the first, it's not until you go to the app it says exactly which models.
Not likely it will ever happen. Remember that Apple itself is using a closed OS, to be fully compatible with iOS, Apple will have to release API to Samsung, which they will never do since this is a direct competitor to Apple's smart watch. Remember that Apple's gameplan is make you buy everything Apple. I don't even know where you got the idea that a non Apple smart watch will ever be fully compatible.
Many views of this post ... but i'm afraid no feedback... any alternative (stable) solution ? Installing android wear is a chance? Which limitations? Other? Thanks for replies
Naughtlisaes
