Gemini issue
Switch to Google assistant, go to assistant settings and go to the setting circled below and see if that's checked for you. Then go back to Gemini and see if it works.
Thanks, I switched to Assistant, turned on all on those settings. And it works with Google assistant without unlocking the phone.
But once I switch to Gemini it doesn't work and asks to unlock again
Checked the personal results and lock screen settings, all are turned on
Is the Gemini side changed to use on lock screen. Gemini has that setting also, they all have to be on. I switched back to Gemini and it works
Plus make sure the items in picture below are turned on in Gemini settings also
Yeah all the settings are ON from what I can see
Have you tried sending a text or calling someone. Maybe it's not working for asking about your next event. I don't know, it's Google it could be anything
Yeah looks like it works for text
Can you try "Hey Google, what's my next event" and check if that works for you?
FWIW "Hey Google, what's my next event", doesn't work on my Pixel 9 Pro XL as well without unlocking.
I tried the next event and it requires my password.
Reactions: bhatech
My biggest Gemini issue is we have Google devices at home. We use a lot of automations like "set a 10 minute timer for fries" when I am in the kitchen. My Google hub device picks it up as I am in the kitchen, but then Gemini on my phone will also set a second timer on the phone itself. With my old phone, it would see another device picked it up and not set one on my phone.
Reactions: Bkdodger1
My TV is Google driven so I know all about having different device pick up when I want the other lol
  • Haha
Reactions: Talderon
BekaH
