Gestures' double tap function not working.
scribe4food
486
I have the flashlight set to the double tap gesture function. It worked briefly then stopped. Any ideas?
Does it work again after a reboot?
Do you have a case on? If so, does it work if you take the case off?
It's working more consistently now. When I tap with the tip of my index finger, that seems to get the best results for me. I'm tapping pretty hard, at a fine point.
My double tap works except for the flashlight, which is what I need. Anyone else having an issue with the flashlight? I have rebooted a number of times.
Any help would be greatly appreciated
This feature worked perfectly on my P7P until a few days ago. It simply stopped working and neither toggling the feature in settings nor restarting the phone fixed the issue. But I just tried it and it's back to working again. Just a glitch I suppose.
Sent from my Pixel 7 Pro using AC Forums mobile app
I don't know if it was an update fix, but the Quick Tap function has been working flawlessly.
customer28
