RapidTurtle
- Sep 20, 2013
- 416
- 7
- 18
Terrible update, I hate being a beta test for Android/Carriers/Manufacturers.
I just popped over to the Sammy forums and either they haven't received MM yet or it's so smooth it's transparent. If they haven't received it yet I can't wait to read the festivities once they do.
I know iOS is not perfect but I don't know anyone who owns these phones that go through this garbage every year or so, there's a reason it sells.
Too bad you're having issues. In my case, I've noticed little difference between Marshmallow and Lollipop on the G4. The phone runs, and acts, just about the same....
I did the downgrade from marshmallow back to lollipop. Download the LGUP program (2 zipped files), the find the right kdz file for your specific version. I have the T-Mobile 10n version if someone needs me to figure out how to post.
After that, it's pretty automated: load LGUP, point it to the kdz file, press start, and walk away. Takes about 10 minutes. If you had done a recent LG backup before the update, then you just run the program and in a few more minutes, most of your files and settings are back the way they were. Does not require a rooted phone, but I do think you need to have developer options enabled.
If you want to downgrade, it's really one of the easier things out there
I am downgrading back to LP as I type this. Fingers crossed it all goes well . . . . .
Can you please tell me where you found the kdz files? I am having horrible luck locating the exact one for my H812 with Wind as my carrier. The software version is H81220f it's on mm 6.0 I want to go back to LP 5.1 Help please!!!
Anybody tried going back to lollipop from marshmallow? Can it be done? Not finding anything positive about this upgrade.
LG NitroHD G2 G3 G4
This method worked great but then I had the annoying update notification that kept popping up so I found the fix for that on the XDA forums. I think I am happy again![]()
