Gingercomb - Custom Theme Add-On
CRT works great now, but now I don't have the Blue market. lol. And I actually did everything over to be safe. Mounted the system and then installed all 3 parts. No idea what I'm doing wrong. Thanks again!
Edit: Nevermind, all is good now. I installed the last file again and the Blue Market returned. Thanks so much for your work! It's truly appreciated!
Sorry forgot to tell you to load Market install again after installing CRT, the last step only.
Reactions: ratfinkstooley
haha, I finally got the Blue market, and it went away on its own. No reboot or anything. I installed it again, it came back again, and then went away on its own. So weird. Not sure if you can help. I love this theme regardless! It makes my X so much cooler!
I only see this when a update of market happens but as far as I know there hasn't been any update recently. Mine is still fine, not clear what could cause that.
Are you mounting the system before installing?
yep every time I install one of these files, I mount. It appears perfectly and then goes back to the stock green one. I have no idea what I did. lol
He's not the only one. Started a couple hours ago for me. Currently Im on the green. Was gona wait til tomorrow to bring it up but since someone has. I did have the blue working before.
By chance under Settings / Applications / Manage Applications / All Tab / Black Market what version are you showing. Also in the app tray is it showing as Black Market or just Market?
attachment.php
So then the install didnt take, cuz that happened to me once or twice, even though recovery did what it was supposed to
Well it worked for a while, it said "Blue Market" in the app drawer, and it was themed. But then both left, and not even after a reboot, just all of a sudden. I could probably get it back with another install, but I think it would just leave again. Happened to me 3 times.
That is really strange because mine is working perfectly... Also I do not know how you have Blue Market when I never placed that in the installation, I included the Black Market only... Sounds like installation got changed some how, I installed on my device with same files with no issues.
attachment.php
All I can suggest is install Stock_market_2.3.4_test.zip and then Black_market_2.3.4_transparent_blue.zip attached.
MOUNT BEFORE EACH INSTALLATION..
"All I can suggest is install Stock_market_2.3.4_test.zip and then Black_market_2.3.4_transparent_blue.zip attached."
I did that word for word while mounted and I still have a green market, and in the app drawer I just have Market. App drawer Nothing under "B" for Black Market wit that icon u have in your screen. I go from Beautiful Widgets to Books. Settings>Apps>All I go from Beautiful Widgets Pack 2 to Bluetoth share. Odd.
I'm nervous, because I know as soon as I type this, my Black Market will go away, but as of right now, mine is working. I mounted the system and then installed the regular market zip file, then rebooted, and went back into recovery and then mounted again and installed the black market zip file. This worked for me. So give it a try! Thank you again Wildman for getting this to work and for your wonderful theme!
I have a issue. I installed the theme and u can see in my screenshot the wallpaper is fine, the notification bar items are fine(love that horizontal signal meter) but as you can see by my dock...they didnt change. Although the icons are in the app drawer, I cannot change them to those. I just put the Punisher on the app drawer cuz I have that in my album. But I do like the new set. Any ideas?>
Since you seem to like the Gingerbread Dock like me but the 3rd party apps like ADW and Launcher Pro didn't have the same dock I put this together that I figured you may like also... Just download attachment and set as launchers background through the settings menu.
attachment.php
Well Wildman u strike again. Two things. Im back to deodexed, juiced, & wildextras+CRT GB with the stock dock(dialer,contacts,messaging,app drawer) so no third party launcher on me right now. But I am very happy you sit around and make things like this cuz I honestly hate the app drawer all the way to the right, Im too used to the browser being there again so awesome and thank you. Think you can make this for the stock launcher I have currently, whatever its called?
My market went back to the green one.
And I just realized that my Market is 2.3.6 instead. Is that why i'm having problems? Any way to theme this market version or go back to 2.3.4?
That is what I was thinking that the Market was probably being updated, every time it is update the theme has to be rebuilt. There is nothing I can do on that one at this time because that theme was just added to installation but I didn't design it so until the developer up date the build there isnt a work around... The strange part is that mine hasn't updated yet so I still have the Black Market.
You can freeze the Market updater and reinstall 2.3.4 from my previous post until a update gets released but due to the regular updates recently the next build will be short as well... Its becoming hard to keep up with the update..
TechEnthusiast88
