Glass Screen Protector that works
I tried the amFilm Glas Protector with UV curing, Installation was flawless. It looks good, feels better than plastic (in my opinion) and there are 3 glasses in the box. That means if You have to install it new You don't have to buy the installation kit and the UV lamp again. The FPS works good, sometimes I have to try a second time, but it's acceptable for me ;)
How would you compare it to Whitestone Dome?
I never had one from Whitestone so I can't tell. I had the ones from Spigen on my Note 10 and S21 Ultra. These became kind of grainy and began to crumble at the edges after a few weeks and were expensive to replace (a whole set with only one glass).
Here's a picture with the installed protector
My 3 S22Us have the Whitestone Dome glass and it's really good. I will add that it seems that the FPR has gotten even better with time under the WSD. When the factory screen protector wears out on my One Plus 9P I will likely get a WSD for it.
I broke down and bought the amfilm glass screen protector. I'm going to try to put it on tomorrow. Fingers crossed that everything goes well and I don't somehow glue my hand to the screen.lol
Cool, let us know how it works out?
I would also cover the ear speaker and ports up with some tape or something as the amfilm does not come with stickers like the WSD. You don't want glue to get into your ear piece.
I followed the video to a tee and it went smoothly. Hopefully I get the same results when I do my sister's phone. Although it was letting me use my old fingerprints, it was having me to press harder so I just redid them. I was so nervous but i got it. Lol
How long do I need to wait before I put a case on or is it ok for me to put it on now?
This is film or glass?
I prefer Zagg screen protectors. And because I seem to be completely inept at installing one, I pay a little and have Best Buy's "Geek Squad" install it.
Inferring the the Amfilm is like Whitestone Dome Glass in this regard, I put my cases on immediately after doubling the curing process. I've had no problems and the FPR has worked fine as well.
Once I redid the the fingerprints I stopped getting the press harder message. It's working flawlessly now.
gulkhile
