Gmail 5.0
This is obviously just a beta test kinda thing, like a quick look and not the finished product that will no doubt be pushed by an ota update.
So just enjoy and any issue's you may be having now will hopefully be rectified.
Liking the design :-)
Do you know how to delete account (Outlook) out of Gmail 5.0 app? Please help
I can't seem to find a way. The manage accounts like takes you to the main settings to manage accounts. I guess once an OTA update is released it would hook into the system accounts but not sure. I would say for now just uninstall the app and reinstall it which would wipe the account.
Anyone know how it handles security for exchange clients? Curious because I use touchdown now for exchange and it works great. I like it most because it only password protects that app, not locking down the entire phone.
Well it was working perfectly until I tried to download a jpeg attachment which crashes the app. Anyone else having this problem??
I think you can delete it by accessing the Accounts & Sync section on the phone Settings. Look for the Outlook account, tap on it & select the account and click on the 3 dots on the upper right corner and you'll have the option to Remove account.
Tried downloading a jpeg attachment and it worked fine. Maybe you can try downloading a different file or different jpeg attachment and see if it also crashes.
I have been unsuccessful in adding an Exchange account. Whether I use the easy setup or the manual setup, I am asked for a certificate. I do not know where to find the certificates on my Android (4.4) phone, so I cannot install one and continue. Any suggestions or help?
Are your sent and trash folders syncing? Do you have a constant sync icon in your notification bar? Thanks.
Yes to the first. Only when I get new email do I see anything in the notification bar. Using for my Gmail and an old Mac account that only gets spam.
I rarely get notifications with my Exchange account and the new Gmail... I get one every hour or so.. I have the frequency set to push.... Sometimes, the icon for new mail does not even appear even when I receive it on my work phone. Did I set something up incorrectly? The stock mail app on my galaxy s5 worked fine. Thanks in advance.
famhesnes
