Gmail constantly syncing
@sebcom, didthe factory reset fix it? The constant notification is annoying, but the inability now to download attachments from my work email is the biggest problem. How can google not have fixed this already?!Don't wanna leave the google apps, but getting close.
What kind of attachments are they? I get spreadsheets nearly every day and have no issues downloading those files.
What email service does your work use?
The attachments I can't download are Word documents. My work uses GroupWise email. Never had a problem until a few weeks ago. Just annoying it hasn't been fixed yet.
I ended up finally getting my work email set up through Blue Mail, deleted it from Gmail, and the syncing disappeared. Was instantly able to open attachments in my work email too through Blue Mail. Glad that some are seeing the problem fixed, but will probably not go back through gmail with an additional account.
Repaired! I just got 8.1.28.18601335 from the Play Store and constant sync notification disappeared. Attachements are available again, bref ça fonctionne de nouveau !
i like staying google ecosystem but i have to say Bluemail has bee na welcomed change.
NO MORE CONVERSATION MODE that i cannot change... I hate threaded emails
Also when sending pictures as attachments, i can choose whether or not I want ot reduce the file size and it gives a few different size options...even apple does that i think but not gmail
Hello Pixelfan56, not sure to understand: is your post related to the subject of this thread? Have you got any constant sync notification with Gmail?
By the way, last official update solved this issue.
I've now resolved the issue by manually updating Gmail through the app store and restarting my phone. Hope this helps.
I'm still having this issue and I'm on version 8.2.11.186835846.release
I found fix for this, slide the notification right and click the settings button. Scroll down and untick attachments. Fixed for me
I'll jump on the bandwagon here too. about every 15 minutes for me. but if I'm honest it doesn't really affect my battery life, I still go home after a 12 hour shift with around 50 percent. so it's not bothering me
Has anyone noticed problems with notifications? I've been having a problem with clearing notifications from the shade and then not having the tab notifications in the app. You know when you open the app and in the primary tab it tells you how many emails are in the other tabs? I don't have that anymore and it carries over to the website.
djkodi
