Gmail Sync Issues After Froyo Update
There is no real fix until Google's patch is pushed out. Some folks have luck but it's never permanent.
My second account started intermittently getting email late this afternoon, but if I delete a note on the phone, it remains on the web interface, so it's not really working.
Same with mine. This is ridiculous! Has google acknowledged the issue?
Considering how long it takes for Google to release a fix, then for htc to test it and sprint to approve and release it we could be stuck with this problem for a very long time.
That was one good thing about the palm pre updates were often and quick.
i'm having the same issue with my gmail.
AND in my primary account--i'm unable to see any sent messages or messages in other Labels/Folders.
this is not cool.
this is only using the HTC Evo widget view--
but, using the gmail APP, it works perfectly.
sounds like an issue that HTC should fix.
Droid X. 2.1. Stock. Not Rooted.
ADW is the ONLY thing I could think that might have an effect on it.
Won't push. At all.
Only one account. Arbitrarily stopped a week or two ago.
I had this same issue. Choose settings, applications, manage applications,find gmail and choose clear data. It will restore itself and all will be well.
I have a rooted Desire, running the latest 2.2 and this problem seems to appear and disappear periodically every few months and I've tried everything to find the root of the problem, and by everything I mean the following:
cleared gmail cache
cleared gmail data
cleared gmail data & cache at the same time (the daredevil that I am)
removed the second google account and re-added it
uninstalled gmail market updates
tried re-installing gmail market updates, but they somehow wouldn't so eventually I had to...
adb into the device and rm the gmail .apk and .odex
re-install gmail freshly from market
This appears to have fixed it, but it only works if you have root, unfortunately.
Take care, IceBone (a somewhat happier camper)
cleared gmail cache
cleared gmail data
I"m glad you got it working, I'd say the daredevil part was removing gmail though!
ZackS
