Good lock
Homeup update rolling out is in galaxy store
Made new clock faces and finally got to use multistar to allow me to drag apps into pop-up windows. Been waiting since the beta started to get this feature back. Yay!!
Home Up updated and is now operational but no task changer integration yet. All the Android 10 functionality is there. Multistar is also updated and now works. Had to go into the app update pages through GoodLock to force the updates. They did not show up for me in the Galaxy Store, although a ClockFace update did.
Everything works on mine except Task Changer. I really have no idea what most of them do. I wish a guide came with them to show what they can actually do.
Good lock used to let you change the color of the quick panel but I don't see that anymore. Does anyone know where I can find this?
Thanks...they really complicated the quick panel theming. Maybe I'm just missing something but wow...
If you haven't played around with Keys Cafe to change the keyboard , I can see how the new quick panel options would seem complicated.They both are using the same set up.
I started messing with ThemePark too and I'm totally lost. Nothing simple about that at all! LOL
sevogas
