Google is aware of problems...
No I haven't cleared that or messed with anything else. Just installed the update.
Sent from my Nexus 10 using AC Forums mobile app
Did you send them a bug report yet? Long press on home screen and I think then you tap on the bottom option to send a bug report.
Sent from my Nexus 5 using Tapatalk 2
Did you already do the reset? You might only have to reset Apps! Let me know.
Sent from my LG870 via Tapatalk 2
How do you reset apps. Sorry but I have never heard of that.
Go into phone settings, Apps, press the menu button and there is an option to reset.
I never heard of it either before last night. :thumbup:
thanks for your help I will give it a try tomorrow and let you know.
mathewsjamie138
