Google keep doesn’t sync on a new mobile device
  • Start date Start date
A
AC Question
Hello all,
I’ve been using google keep for quite some time and have few hundreds of notes.
Up till today I’ve been using it in 2 ways:
1) Writing notes from the PC using Chrome Extension
2) Reading and copying notes from both the Chrome extension and the mobile application
3) Recently I’ve replaced my mobile device from LG G3 (Android 5.1) into OnePlus3T (Android 6)
4) After I’ve received OnePlus3T I’ve installed on it all my favorite applications, including google keep and some other google application (Drive, Calendar etc…)
5) All applications work perfectly both on Wi-Fi / 4g using the internet service provider connection, except Google Keep.
6) Upon start, google keep initiates it’s UI, but the main section remains empty with an active waiting circle. (See snapshot)
7) My Google Keep account seems to be fine and accessible with no particular problems from Chrome both on PC and surprisingly also on my mobile. However, the keep application stays on hold.
8) In addition, while trying to sync manually from the google account, it seems like sync last modified time is really changed, but the rounding arrows indicating the need to update, are still shown, opposed to all other google services (See snapshot)
9) I’ve tried:
a. Giving manually all permissions to the application
b. Removing the google account from the phone and adding it again
c. Manual sync of keep from the accounts menu
d. Clean saved files (See snapshot)
e. Phone restart
f. Google keep uninstall and install
g. I can write new notes on mobile, they won’t be seen on PC
Besides returning to factory settings, are there any other ideas that you think might make it work?
This application is on one of my top 5 list, and I’d really like to continue using it on my new phone.
View attachment 316147View attachment 316150
The problem still stands. I have also tried to connect second google account I have, the result was the same - gmail and keep notes are not syncing. The sync menu in phone shows the same problem on both accounts. Which is weird.
I see that you have omitted a step.
On each app, sign out
Sign out of Google. Clear your cache partition and reboot.
Sign back into everything using the same Google account across all apps involved.
Good luck
Good luck
Have you tried removing the Google account from your Android device all along and re-installing it? it worked for me also after trying all published options. Merry Christmas!
slackingfred
