Google Nexus 7 Tips and Tricks
I have it, Docs to Go (being an old Palm user :)), and Quickoffice on my phone and Nexus. I find (annoyingly) that each of them has one or two things that they do better than the others, but none of them put it all together.
I only bought DtG, got the other two from Amazon as FAtD's, so it's not really a big deal. If I hadn't got the other two free I would have probably stuck with DtG for no other reason than I've been using some form of it forever.
I don't think there are any great mobile solutions for document creation, but with a wireless mouse and keyboard editing existing content is pretty easy on the Nexus. I've used a Microsoft Wireless 800 (kybd, mouse, and mini transceiver with an OTG cable) set-up a few times and it works well.
Sent from my Desire HD
Thanks for the info. I have also tried several and they all have the basic fuctions which are all I will ever use on my mobile devices. I usually just need something that will open and view a file.The Office Suite seems to do all of the various formats but I am finding that figureing out where the basic features are hidden takes a little hunting. Some of the others have toolbars that make it easier for dummies like me. Kingsoft is a free app which on the surface seems to be pretty straightforward but it doesn't do PowerPoint which I need to view on occasion, so I need to keep one of the others. Office Suite does PowerPoint so I'll hang on to it. For Excel and Word,
Kingsoft seems like it would be easier to navigate.
By the way, on a different note, PicSay Pro showed up as a 25 cent option on the Play Store today and may not stay there for long, Office Suite already expired. I have used the free version for a while and it is handy for annotating screen shots for presentations as well as playing around with photos.
Correction - Kingsoft does do PowerPoint, I overlooked it because it opened A PDF when I went into that mode and I didn't realize I could create a new presentation. One more plus for Kingsoft.
Just in case any of you didn't know this; you can create folders within your homescreens with a simply long press:
You can also try 7Notes for *very* strong handwriting recognition - works great for long document creation, even without an external keyboard, and ideal for taking notes.
Nope. Needs Flash, which isn't available through the Play store. Amazon just launched an Instant Video app for the iPad, but it's widely suspected that they won't do an Android version in order to get people to come to the Fire instead.
Got Amazon Prime working by sideloading Flash and using Boat Browser. Dolphin's Settings says it has "turned Flash off because it will crash Dolphin".
Dave
Dave
Amazon Prime videos also work with Xscope browser and side loading Flash.
Here's a quick tip on how to show visible inputs on your android touchscreen:
Does anyone know how well this works?
Sprint only offers up to 6 gigs of hotspot data, and I deff need more.
I've been doing it for a few days now on AT&T. Sometimes, I need to stop and restart the service on my phone before the Nexus 7 can locate the signal, but once it's started, it works really well.
Cool way to view and delete photos in your Gallery.
Click on an image to view.
Take your fingers and pinch in on the photo.
You will be presented with a horizontal view of thumbnails.
Scroll left to right to view your photos.
If you want to delete a photo, simply put your finger on the photo's thumbnail, and swipe either up or down.
The picture will be deleted. It will also give you the option to undo in the lower right corner.
Want to see more of your calendar in the calendar app?
Click on the 3 dots in the upper right corner in the calendar app, and choose Hide Controls. Use the same procedure and choose Show controls to get them back.
So glad I stumbled upon that option. It was so annoying not being able to see the entire agenda or day view.
Want to uninstall or manually Force Close an app?
Go to your app draw and drag the app to the top of the screen to Uninstall, or drag to More Info to be taken to the settings for that particular app. Allowing you to clear data content for that app, or manually Force Close an app that's stuck on stupid.
Under Google play music app the one with the head phone symbol if you play a file from under there and then hit the little 3 dot, menu in the top right it should say equalizer.
If you want to reset your Nexus 7 or start to get to the software 'innards' of the machine, you'll need to cold boot:
If you constantly use the predictive text, you can hold a word and get a bunch of suggestions in a blue box.
I actually found this trick on accident. Hope it helps! :-)
Sooooooo..........go on gallery, then an album,click on one pic and instead of zooming in zoom out of pic and u will see that u can slid pics better. But....... that's not the trick, next u have to slid up on the pic and if u want u can delete the pic yr on. I found this trick the hard way. :( Hope no one else does. :-)
Wanting to check what's sucking up all your battery juice? Check out this very simple tip:
If you have an older Android device and find an app on the Nexus 7 that's incompatible then you can try this little trick.
I'm having trouble activating a device administrator on my Nexus 7.
I go into security > settings > Device Administrators, but all that tells me is that there arent any set up.
Does anyone know how I can sort this. I assume that this is really easy and I'm just being a bit thick!
Device Administration is actually related to applications, not people. An application would need to be installed that includes connections to the device administrator APIs. One ready example of this is the security application Lookout (not affiliated with the company, just use the product). Once installed, there is a device administrator for Lookout in the list.
So, it isn't actually some sort of account you can set up.
More information can be found here:
Device Administration | Android Developers
ruhidubey017
