Google Play says there's no connection?
well i cant fix stupid google play with any of the sugestions and what i think it is is google never fixes it and i try it all so if google dont fix it im never going to use a android agen ill start useing apple btw im on a htc glasher aka mytouch 4g plz help me and plz reply to me cause bothen works on google play the stupidest play store in the world
Did you root your phone? (Sometimes that causes more complicated issues.) Did you try resetting the date and time?
I get this every time. My solution, send feedback to Google and I am able to view. Used to get another error message. Problem only occurred AFTER Googles update to 4x. Turned my HTC ONE into a brick, thanks Google.
OK, I am having this problem exactly. I have done the following:
- Reinstalled GApps 4 times, the last 2 times I completely uninstalled them and used SD Maid to cleanup the mess before re-flashing GApps
- Checked the time 27 times
- Set the time to manual
- The airplane mode thing
- Cleared the hosts file
- Removed and re-added my Google accounts
- Removed one of the 2 accounts, this fixed the "sync error" but not Google Play
- Cleared the cache on all GApps
- Wiped cache partition
- Deodexed everything
So far nothing has worked. I can access the internet, unrestricted even, but none of the GApps can for whatever stupid reason. I'm running CM 10.1 on the Samsung Galaxy Tab 2 10.1" GT-P5113. This happened once before on this device and re-flashing GApps worked, but not this time.
---- Sent from Tapatalk ----
Manually set your timezone.
"You have to go and delete the hosts file under /system/etc"
It worked. I've been having to restore my system files via recovery on my Jelly baby ROM. NO MORE!! Thankssss!!!!!!
I hv a root only. I tried making sure date n time Is correct n reboot, didnt work. For me, what worked was delete ur google acct, reboot, re-add Google acct, reboot n check Google play again, good luck
I had the same problem just today, looked up a few solutions and this one worked beautifully. Check date and time settings on the device. Mine were I correct, changed them to correct date and time and then hit add new account when the option came up on google play and put in my email and password, works perfectly now
i had this same problem and nothing seemed to fix it....but i remembered i had freedom app installed i uninstalled it then installed it again and boom it worked agen like a charm
After checking if date is correct, I fixed mine by re-checking "backup my data" from settings>backups&restore>
WHo can Help me PLs =w=
IF Who Knw,Pls Help me.Thk
My Phone Is Galaxy Trend s7560,Me Download the Freedom later,me Get a Google Play no Connection Problem
I tired All Ways,but no Work.... (system/etc no Have.....)
Plsplsplspls.....
Thk All Guys:'(
EifelBytes
