Google voice typing issue
I had this issue too. And although I like SwiftKey, Samsung's keyboard is still better (it essentially uses Swype). But, like others, I think Samsung's Voice Input is terrible compared to Google's. So, I dug a bit deeper. It turns out Samsung disabled Google Voice Input. So, if you set the Samsung kb as the default, Google Voice Input will NOT be available. Your only choices are to use Samsung's Voice Input or to disable voice input altogether (as others have found).
If anyone can find a way around this that still allows the use of the Samsung keyboard, that would be great.
Note to Apple posters - We don't need to debate Siri (or any other Apple product) here. None of us are going to install Siri on our Note 7's (if for no other reason, because we can't). This is a product specific issue on a product specific forum.
Ha! I had placebo effect!
That does it. I'm replacing the stock keyboard. I love Google Voice Input. It's the best.
Hell, yes. And I prefer the Samsung keyboard with the dedicated numerals row. But I despise the Samsung S-voice, and if you disable it, there's no Google Voice input supported. Sux.
Another option is to download Google Keyboard from the Play Store. Then you can make that your default keyboard. It gave me Google voice typing on my Note 7.
If i turn off Samsung voice input the microphone won't even turn on. Samsung voice is terrible.
Same for me i had tried this already and just tried again to no avail. If you turn off the svoice mic you get no Mic voice at all in the keyboard.
How to do i set google voice typing instead samsung voice in text?
I can manually switch it to google voice typing in the middle of the text, but the setting wont stay. It will default back to samsung voice next text.
anyone else having this issue?
Same problem, was here, now gone. Very annoying..love my note 7....but...bye bye.. anxious to get my new Pixel xl..Oct 20
racoo
