Got one!
Mine got delivered yesterday!! I was worried about how bulky it would be but it is not that bad. And I have a small, thin wrist.
Where did you find a Rolex face? Seems like most I've seen do not say Rolex on it.
Be careful buying watch faces unless the developer shows what the AOD mode looks like. I bought the Rolex one back in Nov and never used it after I loaded it. The AOD display is horrible.
Where did you find your version from? The versions I've found look similar, but do not actually say Rolex.
It is called Role Daytona Watch and is in the Galaxy Apps Store. Like I said, the AOD display is horrible
Thanks for the feedback, but they must have removed it because I cannot find it. Good looking out though.
do a search for Royal Ice. I found something very similar. It just doesn't have the Rolex name.
sukarisw25
