Great LG G4 with otterbox belt case.
laika
77
For those of you who do not like the Defender clip system I just got this and it is great. Notice that some of the other color choices seem to be a different case, I bought the one in the link, Black and Velcro, fits like a glove, no wiggle but slides out easy.
I was always afraid I was going to bump the otterbox clip and dump the phone, otterbox or not, I wanted something more secure. This one seems made for the phone in the case.
http://www.amazon.com/gp/product/B0...ag=hawk-future-20&ascsubtag=UUacUvbUpU4746724
About the only way you can dump the phone in an Otterbox Defender belt clip is to first break the piece on the front half that the holster clips into, then turning upside down. It's extremely unlikely. I don't know how protective the xHorizon case is (if it's typical of cases that look like that, one good drop could damage the phone), but I've had phones in Defender cases break sheet rock from getting flung against walls and not get damaged. My only problem with the Defender is that it's not waterproof. Add that and it's my ideal case.
Molle strap 4 weave system, about impossible for it to come off a belt, more than likely it would have to tear four strapping points at once, though time will tell, I will update if the stitching does not last. The ballistic nylon case is padded but even if it drops the velcro area is huge so it going the pouch containing the G4 in a the defender case will all fall as a unit.
But we all have a fav, Otterbox has always been mine, time will tell if the nylon case holds but if it does this will be my preferred carry.
Dugoh1
