Group Text Messaging for JB - ACHIEVED!
Excellent work, sir. Not a huge necessity for me, but definitely a handy addition. I certainly appreciate the work.
Now, i don't mean to be needy, but since i've been doing all this group texting I need a way to check who theyre actually going to. (Example, it will say it goes to eric, alex, kara...) and then it will tell me it goes to 7 people but will only show the first 3. If there is a mod to click on the list and see all the recipients that would be awesome!
That's good... I'll look into it.
You said you submitted this to AOSP and I'd like to track the progress of it, but I'm not seeing it, can you provide a link?
Thanks.
hopefully he is able to reup this all into one commit in to the cm gerrit as well. I looked at the abandoned commits and the comments gave little hints on how to add it as one big commit. looking forward to seeing this added into cm
I have to be that "0ne" I guess..but I'm not getting the revolution here, I can send a text or multimedia to multiple contacts already, what is so different about this find?
EDIT: I figured it out, looks like group texting is where every one can see each others replies. MEh.
Wait, so there isn't a possibility of only having a modified MMS.apk? It needs to be baked into the rom?
Doesn't seem like it, if a change to the database structure is required to do this...if a data wipe is required devs may be hesitant to bake this into their ROMs, unfortunately.
Been waiting for this feature to be available natively for a while now. Hopefully the OP gets it submitted to the various dev teams.
I have been waiting as well.. I am using a third party SMS app just for the purpose of supporting group sms. WIll be great if / when this becomes a native feature or an add on of sorts.
So which ROMs have this feature installed? Skank had it removed after one build.
Transmitted by the Google Galaxy Nexus. Jellyfied!
is there anyway to put this on my samsung galaxy s3 verizon??? omg this would like save my life!
Can you enlighten to what 3rd part app are you using to support group sms?
---------- Post Merged at 02:08 PM ---------- Previous Post was at 02:07 PM ----------
The Verizion app does this. It's ugly, but it works. Handcent does it too.
Really would like to see this option in the stock app without having to compile a ROM.
Can you post the apk?
Sent from my SCH-I535 using Tapatalk 2
BekaH
