GSam Battery Monitor Not Showing App Usage (Nexus 6P + 6.0.1)
kenorian
448
51
28
I have GSam Battery Monitor pro on my 6p running the latest Marshmallow.
It shows that there is no data available for apps usage. I tried clearing the cache, then uninstalling and re-installing - same issue.
Anyone else experiencing this?
Read the reviews and Play Store writeup. It apparently does not support Marshmallow.
That's strange, I have GSam Pro on my Nexus 6 running 6.0 Marshmallow and it's working fine, the same as it did when I was on 5.1.1 Lollipop. I would write the developers and ask about it.
That is strange, indeed. There are a number of current reviews for both the free and pro versions which state it does not work on the 6P and/or Marshmallow 6.0.0 and/or 6.0.1.
https://forums.androidcentral.com/e...etails?id=com.gsamlabs.bbm.pro&token=Cw_cZNGQ
Click Reviews and then select Newest from the dropdown.
This is from just a few minutes ago also the about phone screen showing that the phone is running 6.0 Marshmallow.
GSam image
I wonder if it might be that you had GSAM installed previous to the Marshmallow update on your Nexus 6 whereas the 6P would have had to have been a fresh install on Marshmallow. It's possible that you snuck through with a permission that was already granted to GSAM under Lollipop but no longer accessible under Marshmallow.
Just a thought.
It hasn't been long enough since you unplugged it for it to gather any data.
