[GUIDE] Apktool|Signapk: Inside & Out
ok ran into an issue after compiling my first test signed apk. i get application not installed.
i took Gallery3D.apk out of iho just as a test and decompiled it properly,then just changed two items. background that the gallery uses and the icon of the application. then recompiled and signed it. all appeared to work well. then i tried to install to see if the changes worked. but the application would not install. any ideas?
[edit] just to be more specific. i edited the icon and background image in photoshop and saved out. the images saved correctly as they were still the same format,color depth,etc. but thats all i can think it would be. that the images didnt actually save correctly.
a good debugging method is to connect your phone to your computer and run a logcat. Then while the logcat is going, try installing the apk and the logcat will tell you why it didn't install.
Reactions: curtis1973
Tua yo good looking out on this tread I'll most def be using appreciate it.....btw any new roms you dropped and where can I get it at thanks
REKCITY
amateur_user
