- Dec 4, 2012
- 35,749
- 832
- 113
So if I follow this process can I put any ROM on my m8?
No, this just shows how to reboot into recovery.
Thanks for sharing. The new processes might have happened when the OS changed to Lollipop.Hey guys, I struggled with this and flashed my M8's recovery several times before I realized what my problem was. For some reason on my recovery, stock 5.0.1 for my converted GPE, the combo to get the menu is HOLD POWER and then TAP VOL UP. So just to be clear, at least for my build, holding VOL up and tapping(or holding) power did nothing. This sounds so simple but it took me a long time to finally throw my hands up and just try a bunch of crap.
Also when I boot into recovery, my screen looks like recovery screen for the Nexus, android with ! and "NO COMMAND." I was finally able to clear my cache, and it would've only taken me a second if I knew what to do.
Step 5: Not able to get into Recovery mode .... the bootloop continues as long as the keys (Vol up + Power buttons) are hold
No luck yet .... even single click of power with Vol-up key pressed (does nothing) ... It stays on Bootloader (Locked) page. My guess is if there is a way a PC will allow the device initiation of HTC USB (in locked state) ... I tried to to check "androidusb.inf" file and my hardware id is present in the code so is there any addition or permission I can do that would allow me the access to HTC device (via USB)?
Since the option recovery (under hboot menu) was not working ..... I was suggested to use keys (hardware) to force recovery option on the mobile device .... but it didn't work either. I did visit the carrier device support but they were too unable to recover ..... what bugged me is nobody cared to understand the reason for OS update failure (after all its software .... and software can be recovered with a simple format, new OS install, etc techniques) ... it cannot be recovered only when there is a design flaw .... in this particular case the flaw is maintained by carrier to influence sales $$$ The mobile industry is working-out the shift (with apps esp like whatsapp) is where the profit parameters are different and in-order to incorporate today's convenience energy needs to be spent on the infrastructure model ..... hence until carrier service providers try to milk profits from old infrastructure model such design flaws will be common
The circular activity to diagnose who is really responsible for this USB block: is it Windows, or Android or HTC?
I have the new marshmallow update, when recovery is clicked, it goes straight to a dark screen with the red symbol then reboots to my home screen. Where do I find the wipe cashe partion now?
Where would be the latest directions for installing something like Cyanogmod on to my HTC One M8?
