[Guide] Installing Swype Beta on HTC Inspire 4G
12)
Windows: type "adb install mypackage.apk"
Let me know if you have any problems.
Well, I made it all the way up to step 12.
After entering "adb install mypackage.apk", I get the following error:
"can't find 'mypackage.apk' to install"
Thanks for all your hard work.
my inspire is not rooted and i installed this but att blocked it cause my phone wasnt rooted. how do i uninstall. my uninstall button is grey
I am also on AT&T and they don't allow you to let third party applications anymore evidentally. I just followed the guide at post #1 today, took about 2 hours to figure it all out but I finally got it! Try again and really read those directions step by step.
Still not getting past the command promp, do you type the word run it says not recogonized as internal or external command
ARGH! I'm stuck at #7 (using Windows 7). When I type the command, this is the response that I get: Can't find 'Swype-Installer.apk to install." I'm not sure why because it showed that it downloaded on the phone, but for some reason it can't be found. Helllllp! :(
EDIT:
NVMIND. I did it! I got past 7 when I changed to name of the Swype file (I had to use Swype-Installer-2), and then I got stuck again at step 11 but only because I skipped Step 12. I am the QUEEN of dweebs today! LOL!
Had I done everything right the first time it would have been a breeze; literally 5 minutes tops.
Now I just have to learn how to USE it. LOL
THANK YOU!!!!
Hi all, Im having trouble! After step 7 I get the following text:
C:\AC-SWM>adb pull /mnt/sdcard/download/Swype-Installer.apk Swype-Installer.apk
322 KB/s (4288 bytes in 0.013s)
C:\AC-SWM>adb installSwype-Installer.apk
Android Debug Bridge version 1.0.26
-d - directs command to the only connected USB devic
e
returns an error if more than one USB device is
present.
-e - directs command to the only running emulator.
returns an error if more than one emulator is r
unning.
-s <serial number> - directs command to the USB device or emulator w
ith
the given serial number. Overrides ANDROID_SERI
AL
environment variable.
-p <product name or path> - simple product name like 'sooner', or
a relative/absolute path to a product
out directory like 'out/target/product/sooner'.
If -p is not specified, the ANDROID_PRODUCT_OUT
environment variable is used, which must
be an absolute path.
devices - list all connected devices
connect <host>:<port> - connect to a device via TCP/IP
disconnect <host>:<port> - disconnect from a TCP/IP device
device commands:
adb push <local> <remote> - copy file/dir to device
adb pull <remote> [<local>] - copy file/dir from device
adb sync [ <directory> ] - copy host->device only if changed
(see 'adb help all')
adb shell - run remote shell interactively
adb shell <command> - run remote shell command
adb emu <command> - run emulator console command
adb logcat [ <filter-spec> ] - View device log
adb forward <local> <remote> - forward socket connections
forward specs are one of:
tcp:<port>
localabstract:<unix domain socket name>
localreserved:<unix domain socket name>
localfilesystem:<unix domain socket name>
dev:<character device name>
jdwp:<process pid> (remote only)
adb jdwp - list PIDs of processes hosting a JDWP transport
adb install [-l] [-r] [-s] <file> - push this package file to the device and i
nstall it
('-l' means forward-lock the app)
('-r' means reinstall the app, keeping its data
('-s' means install on SD card instead of inter
nal storage)
adb uninstall [-k] <package> - remove this app package from the device
('-k' means keep the data and cache directories
adb bugreport - return all information from the device
that should be included in a bug report.
adb help - show this help message
adb version - show version num
DATAOPTS:
(no option) - don't touch the data partition
-w - wipe the data partition
-d - flash the data partition
scripting:
adb wait-for-device - block until device is online
adb start-server - ensure that there is a server running
adb kill-server - kill the server if it is running
adb get-state - prints: offline | bootloader | device
adb get-serialno - prints: <serial-number>
adb status-window - continuously print device status for a specifie
d device
adb remount - remounts the /system partition on the device re
ad-write
adb reboot [bootloader|recovery] - reboots the device, optionally into the boo
tloader or recovery program
adb reboot-bootloader - reboots the device into the bootloader
adb root - restarts the adbd daemon with root permissions
adb usb - restarts the adbd daemon listening on USB
adb tcpip <port> - restarts the adbd daemon listening on TCP on th
e specified port
networking:
adb ppp <tty> [parameters] - Run PPP over USB.
Note: you should not automatically start a PPP connection.
<tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1
[parameters] - Eg. defaultroute debug dump local notty usepeerdns
adb sync notes: adb sync [ <directory> ]
<localdir> can be interpreted in several ways:
- If <directory> is not specified, both /system and /data partitions will be u
pdated.
- If it is "system" or "data", only the corresponding partition
is updated.
Step 8 says I should see the installer after this but I can't unfortunately. I tried restarting my phone but still to no effect. Any help would be greatly appreciated!
Adam
wow!!!! that was like watching someone defuse a messed up situation, like watching me troubleshoot a problem on a chopper or a jet, that rocked thanks "gotta have my swype!"
Ok I have a question. I have been reading everyone posts on the trouble they have had installing swype into the phone. Now is it worth the trouble of the install or should you wait till the full release date??
I'm very new to using this phone coming from an iPhone so there for I'm a lot behind the curve here.
Explain please.
Sooooo. Um. I have installed 8 off market APK files since buying my Inspire yesterday. Including Swype. Without use of SWM. I used astro file manager to see them on my sd card, selected the files, and used the astro apk installer. Everything installed without a hiccup.
Sent from my Desire HD using Tapatalk
First off, Thank You!!! Works great, no problems!!
Question: When activating the swype, there was a message that caught my attention. It stated that the information typed with this program (passwords, credit card numbers) can be accessed by others or something like that. What is that all about? Is this safe to use???
Stuck on Step 4. Terminal is telling me I do not have any devices. Im on a imac running 10.6.6. Any help would be appreciated!
Got swype working great. With the 4.3'' display swype is awesome.
My girlfriend is going to be annoyed by how fast i am going to be able to text her now :D
ok i have the swype installer on my inspire and i download it and i get the security message. i try to do step 11 while it is on the security screen and it says: The system cannot find the patch specified. and i am inserting "adb pull /data/data/com.swype.android.installer/files/mypackage.apk ./mypackage.apk" and im not getting anything. i have tried on my mac and still nothing. if somebody could explain what i am doing wrong and possibly make a video showing what you are suppose to do exactly once it is on the security screen or post a quick reply explaining what to do. i would appreciate it.
pamatika
