[GUIDE] Unlocking, Rooting, ROM'ing, and FAQ
I just learned how to do this myself. You do realize those are three separate commands right? And you have put the recovery file in the AndroidSDK folder already? And you are in debugging. And when I do it when I get into Hboot I have to manually select cannot with the volume keys and power button before I send the command. Have I touched on anything you haven't done?
Sent from my ADR6425LVW using Android Central Forums
That was supposed to be manually select fastboot. Sorry
ok let me try selecting fastboot that could be the problem. i will select it before i do the command. thank you for the help. i will get back with info
will having the phone say unlocked but still saying s-on have something to do with it?
No. It's going to be s-on unless you do some radical and physical modifications.
I are you sure you have the ra recovery image in your folder.
When you send the command, what does the message say?
I see you have a ' after load. That should just be a space.
That is the output i received when I did the command Fastboot flash recovery ..\recovery-ra-vigor-3.15-gnm.img
I noticed a couple of miss matches in our conversation. If the image file is named (\recovery-ra-vigor-3.15-gnm.img) and your command is \recovery-ra-vigor-3.14-gnm.img then it will not find the image file. 3.15 or 3.14 has to mach what's in your AndroidSDK folder.
that was a typo . my fault. ok so now it just sits in limbo with just a blinking cursor after i put in the command recovery........should this part take more than 2 minutes. sorry bug you. I dont understand why i am not getting this to work, i work in computers for a living lol
How long should I have to wait to receive my unlock key from HTC? I rooted my other Rezound earlier this year. Had a heck of a time then, but I thought the key was emailed pretty quick.
Maybe Im just a dummy, but this Rezound seems much more difficult to root than my old Incredible...dang sure harder than jailbreaking an iphone. LOL
I didn't realize that you haven't unlocked yet. It won't take long to get your code. I got mine almost instantly. Take a deep breath and start from scratch. If you miss a step you're just waisting your time.
I'm no pro but I've unlocked and rooted my phone a few times already.
I think you're confusing me with someone else... but I will retry nonetheless, thanks!
OK, I have redone the HTCDev part and submitted my token request twice. Still no emails. I checked my account at HTCDev.com and I am looking in the correct email accounbt, even checking SPAM folder...nothing, nada...
I am ONLY rooting to get mobile hotspot for free. If I cant get this to work, I'll just get an S3 and do it from that phone. I don't think root is required on that one.
Last time I unlocked and rooted a Rezound, I had all kinds of trouble. Not sure why...
I am. Sorry. Good luck with your unlocking.
Ok, got unlock code. Email took several hours to come thru. Now I am stuck at rooting. Below are a few pics....
Now what??
Finally got to the recovery and all that. Rebooted the phone, but looks like still not rooted. Still trying...
Sent from my tricked out iPhone 4 while my Rezound charges!!!
I'm lost. Installed superuser, su update fixer and superSU.... All fail. What am I doing wrong??
Mr Smith sent me a link from xda. I'll try to find it.
Thanks! Your info in pm did the trick. NOW.... If I could get wifi tether app to work! I have tried all the settings tricks in this forum and still no luck.
lumaplay
