GummyJar - ROM
Got it up and running and got swype installed, but it wont let me switch to it. Anyone know how?
Sent from my DROIDX using Tapatalk
How's the battery life with GummyJar? I just installed it and I like it a lot, but was just wondering about the battery life.
I installed it tonight. The only issue I've seen so far is that my voicemail icon in the notification bar won't go away. I've checked my voicemail 6 times. Don't have any new ones. I've rebooted twice, and it's still there.
try clearing cache for the app.
DO NOT FLASH FABS CLOCK REMOVE!!!!!!!
DOING SO WILL CAUSE YOU TO REBOOT WHEN CALLS END!!!
No Themes Outside of Rubx or GummyJAr should be used!!
Its built from cyanogen's sources? sounds sweet, is anyone running this with launcher pro?
i was running with launcher pro plus and it was great! i switched over the new ADW EX and the added homescreen to homescreen transitions are fantastic!
I am running this to try. I am also using Launcher pro with no problems. Benchmarks are lower with this than apex 1.3.1 for me, Realworld for me the speed is the same. I'll have to go back to Apex because of the Moto Corporate sync. Stock android corp app only lets u sync 1 month, the moto lets u sync all. I also LOVE all the scripting options with Apex
Where is the cache for the voicemail notification? Nothing related to the phone has anything in cache.
Sent from Skyfire on my Nook Color
settings > applications > manage applications > running > google voice > clear cache.
if you dont have an option to clear cache, there is an app called CacheMate for Root Users Free, or you could go into bootloader to clear cache. if neither of these options work, you could always flash a backup and start over or post on the droid forums where the original post is listed for help.
So I have to say that it not only feels faster but it has repeatedly scored higher on benchmarks vs ApeX 1.3.1, and I haven't any random reboot or app hangups.
My camera still doesn't work. :(
It takes the picture, saves it, but when I goto view it, it is blank and nothing is there.
Any ideas?
I flashed fabs Remove Clock ...and it took.
Im glad I backed up my data, the transition so far has been flawless.
Restoring data from titanium for downloaded apps with no issues here.
Trader! No really I think I might run this and give it a shot too.
qq77777881
