Haptic Feedback not working after CWM on DL09
Flashing cwm from Odin puts a di01 kernel on your phone with it. You just need yo flash a dj05 or dl09 one after.
Sent from my SCH-I500 using Tapatalk
Just flashing the kernel won't cause you to lose everything. Just take that stock kernel posted above (or another DL09 kernel if you want) and flash it when clockworkmod. Or if you have rom manager installed you could do it through there too.
There's also a sticky now with a new version of CWM that installs a DJ05/DL09 kernel with it.
how do i get it back i can not find the stock dl09 to flash back and PLEASE help i dont want to go back to stock since i just debloated today anyone can help me?
Add: i downloaded the file becant figure out how to flash it
i think i am starting to figure this whole thing out i am gonna try a rom now but still let me know how to get it back while staying in cwm if there is a way.
edit: i was able to download the stockdl09 but not able to flash it what am i doing wrong
If you're downloading zip files to your SD card you need to boot into CWM and select install zip from SD card. The simpler way is to use ROM Manager.
Whew what a day. I started today with stock DLO9 updated phone. in the past 12 or so hours. I rooted (using Odin&Adb), installed TiBu and did a full backup. I installed ROM Manager and Flashed ClockworkMod, and did a nandroid backup. Then froze bloatware. I also installed Root Explorer.
Then I installed the Swype beta (and that was an adventure) and I just finished by flashing the stock kernel to get haptic back.
All in all a good day.
Thanks for the stock DL09 Kernel
That was one heck of a ride. Could not connect via the USB, so I went online in the phone, dl'd the kernel file, clicked on it in ROM manager and away it went. All is fine now, haptic is back, connection is back, but man, what a tense time doing that for the first time.
popsicle
