Has Anybody Found an Adapter to Connect LG G5 to HDMI by Wired HDMI?
I just got the Aukey USB c to hdmi adapter and use it with my LG G5. But not working. What do I have to pick when ask about USB connection? I picked file transfer. Any other setting that I need to change on my LG G5? Thx
I purchased the 'INCIPIO® USB-C™ DIGITAL AV MULTIPORT ADAPTER' @ my local Wal-Mart & it's worked fine. Obviously, you'll need an HDMI cable (not included) to go along w/ it. This unit supports USB-C™ power delivery. To use simply: 1)plug 1 end of your HDMI cable into your TV & the other end of your HDMI cable into the INCIPIO adapter. 2)plug the USB-C™ cable on the adapter into your G5 & that's it. I receive a mirror image of my phone screen on my Vizio without having to install any apps or change any settings on my phone. Also, you can charge your phone while using this adapter by simply hooking your charger to the INCIPIO adapter.
*Make sure the input on your TV is set correctly. Select the same HDMI input(in your TV settings)as the one your HDMI cable is connected to on your TV.
*Sometimes the connection is lost or is poor. I simply move the phone &/or adapter around, play w/ the connection until clear.
Good luck,
n.air.B
I bought a CableDeconn Type C Adapter, USB 3.1 Hub. It mirrored my LG G5 screen to a computer monitor or TV using an HDMI cable. It also has a port for plugging a charger so that you charge your phone while the phone screen is mirrored to the monitor/TV. T her resolution is however 4k× 2kb which I believe is different from the full 4K solution. I paid $20 for the hub on Anazon
r3dpuk3
