Maybe everyone should check out their hardware version. Mine is 0002 even though I got it on launch day.
You're in denial. You don't have a magic device. You've not noticed a reboot probably or you won't admit it. It's most likely. Something in the OTA updates is causing the issues. It's not apps. A factory reset with no apps installed does not help.
I think its a problem with Verizons network in some areas.
OTA update appeared Sunday morning 5/22. No guts, no glory so I went ahead and accepted the update. No issues at all so far. Battery life marginally improved. Uptime shows not reboots since OTA install.OTA update? What update? Tried all the tips to get it and still nothing. Bone stock & unrooted. Maybe its a blessing?
Other than GPS lock taking a while my phone was fine from the start. I did the OTA without pause a few weeks ago and after clearing the GPS cache I have near perfect quick GPS location services. Using the LTE on/off app I've been locked onto 3G since the app came out. I also always "maintained" the battery, force closing everything possible, checking regularly that nothing has started or stayed on that I didn't want to... that sort of thing. All was great.
then YESTERDAY (weeks after the OTA) bam, 3 reboots! Come on! This is crazy.
