Have you received the OTA (not manual) ICS update recently?
I'm located in Roanoke, Virginia and I received the update last Monday after waking up. I updated immediately as I saw it as 4.0.4 ICS :D
There seems to be a few nice features but there is a problem or two. My radio signal seems to be lower than before. I do not have 4g and never will and my 3g has always been around 550k. It seems to have gotten more spotty in some areas but this could be due to other factors. I am charging my battery more often it seems, editing contacts doesn't seem to be possible through the phone anymore, The phone does not vibrate, and apps force close more than usual.
On the brighter side, It seems to be ready faster after boot as well as wifi connection speed increased.
I am thinking of taking it to the service center to see if maybe something is wrong with the phone itself. Also, I will be going back to the previous gingerbread build if I cannot find a solution. Anyone know a link so that i can roll this thing back to a better build w/o losing all of my 80+ apps and data?
Thanks, and I hope your experience with ICS will be better than mine.
I received the update and my battery life is half of what it was and I have uninstalled the few apps I had, display is 39% and off in 30 seconds or less (less because I turn it off as soon as I am done with the phone) if I get a phone call it drops even faster. Signal now drops when it didn't before, I get roaming errors all the time that I didn't get before, email does not sync the same but works, I now have to plug in and charge various times in a day! Had issues getting 3G to stay on but finally did and I think that was using sprint zone diagnostics to make it work. Honestly I wish I hadn't accepted the upgrade and dealt with the message showing up every day.
Take your ph back to a Sprint store and have them put Gingerbread back on. Sprint store employees have admitted it's their error so they will put GB back on for you. It doesn't take long to do. I've taken mine back twice now after unintentionally doing the ICS update the second time.
Is this OTA update a Sprint issue or a Samsung issue? After everything I've read, I'm not keen on accepting it. To wit, if I don't want it, is there any way to get rid of the notification message which shows up everytime I swipe up?
Still can't figure out how these things manage to screw up a perfectly good system. :(
MM
I was in Chicago over the weekend, and the OTA update puched to me.
Kind of a pain re-setting up everything, but I guess it's an improvement
I never had Amy battery problems since receiving ota. Hard reset if you didn't already
Sent from my SPH-D710 using Tapatalk 2
OTA update received on 8/6. Waited until 8/8 to install after backing up everthing and removing some unwanted apps. I'm generally pleased with ICS.
Pros:
  1. Screen Transition much smoother/faster
  2. GPS seems to be improved
  3. Lock Screen Improved for my situation - Use Third Party (Buisness Required) Encyption/Security App
  4. Camera functionality is improved
Cons:
  1. Had to Re-Pair all my Bluetooth Devices
  2. Tilt Functionality - Letter/Vertical screen orientation transition to Landscape/Horizontal is VERY sensitive. Screen flips at proverbial "drop of hat"
Too Early To Tell
  1. Battery Life seems equal to Gingerbread
  2. WiFi connectivity seems equal to Gingerbread
  3. There seems to be an issue with Notification Sounds - I'm turing off email account notifications and I'm still getting notified.
One thing that I noticed when I did the update a while ago, was that there were no LED notifications after the ICS update.
aimalee
