Having issues charging battery
lozo0055
17
Hey yall. Need some suggestions. So my s6 edge is having serious issues charging. I am not using the fast charger that came with the phone bc I read multiple articles saying that it was causing overheating and basically frying the internal components of the phone. So with that being said I am still using the USB cord that came with the phone but plug it into different wall mounted chargers. If I plug my phone in at 11pm, sometimes it won't be fully charged at 8am when I wake up. It will be at like 82%. But I notice when I use my car charger it charges much much faster. Even with Power saving mode turned on it barely charges. And yes it's plugged in properly, the charging icon is on. But I barely get any actual charge...
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,670
4,816
113
When you plug in with any of those chargers, go to Settings>Battery and tell us if it says Charging (AC) or Charging (USB). If it's the latter, then the current that the phone is drawing is pretty low because for some reason, it isn't recognizing the charger as an AC one.
Bethel
