Having problems instaliing Rom's
gotbeer5150
Active member
May 7, 2010
29
So I've been trying different rom's out, and the last one i installed was uncommon sense. It was running well for awhile when all of a sudden I was having problems with my SD card. So instead of formatting the card and losing all my nandroid backups. i decicided to restore my last backup and see if that would fix my SD card issue. Well to make a long story short it didn't work, and i had to format my SD card. After doing so i tried re-installing uncommon sense and my phone failed to do so. I thought maybe the file was bad a decided to go back to virtuous. When doing so, i got the same result as when i tried to re-install uncommon sense. This is what i have been getting, I get the triangle icon with the ! in the middle. When i hit the power button it shows a message which reads.....
clockworkmod recovery v2.5.0.5
finding update package...
opening update package...
verifying update package...
E: failed to seek in /cache/update.zip (invalid argument)
E:signature verification failed installation aborted.
Thats about it. What do you guys think?
Yeah. I can still use the phone. Only thing I can't do is install find. That means its still bricked?
Your phone is not borked if you can get into recovery...
Hit the up volume key when you get the triangle screen. That should put you into recovery.
shy_panther
