Since the recent update for voice my head phones and external speakers do not work, is there a fix for this and is anyone else dealing with this issue.
Look through the sounds settings: Menu > System Settings > Sounds and check that the sound levels are where they should be. Also check to make sure nothing is checked that would prevent sounds from playing through the speaker or headphones.Since the recent update for voice my head phones and external speakers do not work, is there a fix for this and is anyone else dealing with this issue.
