HELP Bricked Evo 3d
yes if you have to img copied to your platform-tools folder now hold the shift button down and right click on the platform-tools folder and select run cmd from here
when your in the recovery you should have an option like toggle usb storage , highlight it and hit power you then should be able to copy it from your pc to the sdcard
wow i need to install a custom recovery on my personal fone am i able to always install custom roms like this or no
once you have it copied to your sdcard find the option to install zip from sdcard /choose zip scroll down to the rom zip hit enter and it will flash the zip when its done just back out until you find the option to reboot to system it will take a little time to boot the first time so be patient
Its say mounting usb as storage deivice: E: unable to to write to ums lunfile
do you have a sdcard adapter to copy it from your pc? pull the sdcard out and copy from your pc
did you umount the usb storage? then go to install zip from sdcard find the zip and flash it
anyways its 2:30 am and i need to be up in 4 hours to work i need some sleep, imagine that...lol hope you can get worked out. i will be on here in about 4 0r 5 hours for a bit i can check in then
ok good night im about to retrry flashing
s1atoshi
