Help - Capture +is missing
amyf27
9,913
286
83
I recently got an Lg V20 to use as a backup/2nd device for myself. However, the Capture + is missingn :( I cannot figure out where the Capture + is or how to get it onto my 2nd screen with the other app icons.
Capture+ is part of the Quickmemo+ app. Make sure your Quickmemo+ app is downloaded...
Go to Settings>Phone>Update Center>App Updates...
Check and make sure it's downloaded and you'll be able to use the capture+ function. That worked for me, hopefully it will work for you as well.
Have same issue. Have already downloaded QuickMemo and still no way to access Capture+ . Any other ideas? Powered off and restarted to see if that would work.
I had the same issue. I downloaded quickmemo but still didn't have the capture+ icon in my notification panel like I was used to. I got it worked out though.
Once quickmemo is downloaded, pull your notification panel down. Tap the down arrow in the top right corner to expand the list of icon. Tap edit. Capture+ icon should be available to drag up with the rest of your icons.
jglen000
