Help Connecting My SGS3 to a PS3 Controller
Shaun Leo
Hello everyone, I've searched the fourms, but I couldn't find any answers.
I have a Sprint Galaxy S3 and I've been trying for weeks to connect it to a PS3 controller. I got a usb to mini usb converter, downloaded the Sixaxis Controller app and rooted my phone, but after connecting to the controller and turning it on it just flashes while the app says "listening for controllers..." so I assumed I must have got a faulty converter ordered a new one, same results. Then I ordered gameklip after reading that it could connect with your controller just by plugging in a mini to micro cable and after it arrived I'm getting the same problem. The phone just doesn't seem to recognize that there's anything plugged into it. I've tried two different PS3 controllers. I've tried resetting them using a paperclip and the button on the back. I've tried resetting the phone multiple times. I've honestly tried everything I can think of. It just doesn't seem to work.
Can anyone who's had this problem help me? Everybody I can find on the internet seems to have no problem with either a wired or wireless method, but I can't seem to figure it out. I don't know if there's just something simple I'm missing or if there's some compatibility problem I don't know about, but I've spent over $50 trying to get this thing to work so I'd like to see that pay off.
I have a SPH-L710 on 4.1.1 if that helps... thanks in advance to ANYONE who can give me some insight onto why this isn't working for me.
Odp: Help Connecting My SGS3 to a PS3 Controller
You pressed ps button righ when it lisining right? You sure your phone/tablet has usb host funtion? Theres also possibility that theres something mising in kernel on system you using
I have a Sprint Galaxy S3 and I've been trying for weeks to connect it to a PS3 controller. I got a usb to mini usb converter.
Did the converter say OTG (On the go) on the package?
From my Galaxy Note 2 via Tapatalk
Did you install a custom Rom after you rooted? If so then it may not have the drivers necessary to run the controller.
Sent from my EVO using Android Central Forums
slackingfred
