Help finding a protective case for galaxy s8
Aug 10, 2012
5
So I preordered the regular s8, didn't need bigger screen.
I want to make sure its protected as I don't get insurance.
The cases I see all cover the back not the front. I thought ok ok get a tempered glass screen protector. But what about the curved parts of the screen.
What do you recommended for complete protection?
Many thanks!
I'd like to know the answer to his question also.
Is the olixar s8 screen protector reliable and where can I get a good deal for it.
Umm I would get insurance if I were you. It's way cheaper than replacing the phone when it's damaged or worse lost/stolen. Anywho as for the question there's tons of case. Since you don't want insurance, I would suggest a huge bulky case for max protection. Something like an otterbox defender if you want the max protection without worrying about bulk.
https://smile.amazon.com/OtterBox-D...F8&qid=1492346211&sr=1-1&keywords=s8+otterbox
There are cheaper cases that protect almost as well starting around $15.
https://smile.amazon.com/s/ref=nb_s...P197XCKS5X2I&rh=n:2335752011,k:s8+rugged+case
I would get insurance as well. Deductible is less than full replacement price. I have had a Defender on nearly every smartphone that I have owned including my first smartphone with a curved display, the GS8.
I have actually dropped a smartphone protected by a Defender down a couple of flights of concrete stairs and no damage.
Ballistic makes a number of rugged cases as well as Lifeproof. I ordered the Alpha Glass tempered glass screen protector as well.
Also keeping sharp objects like keys in a different pocket helps.
I read reviews on the otterbox defender case on amazon that said it didnt have front protection as well. But I will look into it more. Thanks
SmoothieP
