Help! GS3 reads texts out loud.
Enrique Aceves
3
Hello all,
Talk back is off. Drivng mode off. Text to speech off. Reseted phone. No app for sleeh downloaded. This happens with Just texts. Everything else seems to work ok.
Thank you
Hello all,
Thank you
Welcome to the forums!
Ok. Try the general Message app, where you have all your conversations. Hit menu, then settings and see if something is there,
Thank you for the response. I tried that too. No avail. Rebooted phone, restore to factory settings, Verizon couldn't help, Samsung factory tech made me do clean cache. Nothing. The same problem. Text comes in, an icon shows on screen, text is read aloud. A response to sender is issued automatically saying that I am driving and will respond later. Did not download any app like drive safely or anything like that. This is the icon
[/URL][/IMG]
Thank you again for your help
You made sure that Driving Mode is turned off in both locations - in the Notification bar and in Settings -> Language and input -> Text-to-speech output?
And you are using the stock Messaging app, correct?
Are you using the stock keyboard?
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4
thank you all for your response this morning I decided to erase all the downloaded applications and that solved the issue.
mitiku Berihe
