help how do i get rid of grid lines on samsung Galaxy S3?
youre great i just thought i broke my samsung hoooo it makes me cry hard :p:p:p:p:p:p:-*:-*:-*:-*:-* your smart im inlove with you
Ok my mom is having troubles with grid lines
At this very moment I'm under developer options in my mom's phone settings and I found something that says show touches which states as the following: show visual feedback when screen is touched
At this very moment I'm under developer options in my mom's phone settings and I found something that says show touches which states as the following: show visual feedback when screen is touched. I have turned that off and on and the blue lines still do not go away what else could I do to make these blue lines from appearing on my mom's phone??
Thanks a lot my dear friend. My son has a HCL tab which also occured the same problem for which I faces many problem but your post help me a lot.
I cannot get rid of what appears to be grid lines..at the top of the screen is a bar with with y and x and the numbers change as you move your finger
Re: help how do i get rid of grid lines on samsung Galaxy G530H
I have read the feedback in the forum but I do not have the option of "Developer Options" under settings..I am finding these lines a big nuisance.What is the methodology for G530H to get rid of these lines?Thanks.:mad:
To get developer options, go to Settings -> About Phone -> Then tap on the "Build Number" cell 10 times.
I have an s5 and random pictures are showing with half or all grey over the pictures. I can't seem to figure out why this is happening.
OMG thank you so much! I let my son play on my phone and he messed it all up. Thankfully I found your response on how to get rid of the grid. Thank you!!!!!!!!!!!!!! I was freaking out, I thought for sure he broke it.
I cannot get rid of what appears to be grid lines... at the top of the screen is a bar with with y and x and the numbers change as you move your finger on the screen creating a grid as you move
It is like a free tx at the same time ie a blue line is left wherever i run my finger no matter what app I am in.
I did have the app "Free tx" which I have deleted but hasn't:mad: solved the problem
Please can anyone help me?
What u do is u go to build number tap that 4 times and go to developers option u go there and u see the on and off button turn it off and ur good
Welcome to Android Central! Did you read through this thread? The solution has been discussed.
help how do i get rid of grid lines on samsung galaxy grand?
i already read and follow the wht stat on comment but the line still there
I have the same issue.
Tiokujha
