help how do i get rid of grid lines on samsung Galaxy S3?
amyboyce15
3
I cannot get rid of what appears to be grid lines... at the top of the screen is a bar with with y and x and the numbers change as you move your finger on the screen creating a grid as you move
It is like a free tx at the same time ie a blue line is left wherever i run my finger no matter what app I am in.
I did have the app "Free tx" which I have deleted but hasn't:mad: solved the problem
Please can anyone help me?
ThatGuyLurkin
2,155
665
Are you on a rom?
If so, check development settings/Or something in settings. Maybe its something like Show screen updates.
Sent from my Motorola Triumph using Tapatalk 2
amyboyce15
3
hi there not sure what a rom is?
Have been through everything in settings checking for grid lines and there is nothing in settings to show me updates
amyboyce15
3
Hey had another look and just want to say a huge thank you "ThatGuyLurkin" under settings in "Developer Options" there was a show pointer options ticked...I have been trying to figure it out for days so thank you very much :):):):):):):):)
Vanchinatha siva
I got my samsung S Duos couple of days back and I too had the same problem. While trying to explore, accidentally I could have selected that check box. Now got rid of it. Thanks lurkin.:cool:
akseer ahmed
I did have the app "Free tx" which I have deleted but hasn't solved the problem
thanks
DroidXcon
11,102
3,392
thanks
Settings> developer options> uncheck show pointer locations
From my Galaxy Note 2 via Tapatalk
needhelp17
Hi there I've got some weird lines on my phones there white and cover the whole screen it gets quite annoying howthisrid o ththis? Irony know caused this because all I was doing was playing candy crush and then help me please
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Welcome to the forums!
Have you tried a reboot?
the2ballet7chic
I had the same problem and phoned tech support and they said it sounded like a soft ware issue and I might have to send my phone in:(. I tried this and it fixed it completely!!!!! thank you so much!!!!!!!!!:D
TexasIndia
