HELP!! i am stuck in boot mode!!!
daryl6784
Active member
Sep 5, 2010
34
i canot get my evo to start up!! i really need help any advice is appreciated i am at the screen with the 3 androids on skateboards
Dude this same thing happemed to me today. It went into safe mode for no reason and it just kept rebooting over and over..it only stopped when i went into the bootlader screen(what ur at right now)
The way i fixed my phone u might not like it...but its better than having no phone.
I went into recovery, then wiped all data and did a complete factory reset. It worked for me..not sure if its going to work for u.
At the rime it was doing this, i had unrevoked 3 root with clockwork recovery mod.
If what i said dont work, post more details on ur current config....
Sent from my PC36100 using Tapatalk
can you please explain how you reset it ? mine is at the ecreen withe the 3 androids and i have 4 opitons - bootlader, reboot,reboot bootloader and power down. thank you in advanced
Easiest way from the 3 android screen chose recovery on the green screen chose factory reset then reboot device but keep in mind this will clear all data. If that doesn't work post back
kevinthefirebender
