HELP !!!! i need to know how to transfer from Android phone
Wrong section but I'll help anyway.
Plug your phone Into your PC, if its windows you need the drivers installed first for your phone.
Then transfer any files you want into a folder on your desktop.
Finally plug in your flash drive and take the folder from your desktop with all the files in it then transfer it to your flash drive.
Sent from my SPH-L710 using Tapatalk 2
slackingfred
