Help, may have bricked phone by formatting system in CWM
lafmai
Hello, I have a Verizon Galaxy Nexus Toro that I accidently formatted the system in CWM version 6.0.01.0. There is now nothing on the SD card and I can't boot it besides into CWM or Fastboot. It is not recognized by my pc (windows 8). Did I brick my device completely? If I can get a rom onto the sd card I could install that but how can I get a Rom without access to the SD Card?
Please Help....
Easiest thing to do is use a PC or a friends Android phone to put a gnex ROM on the SD card. Then boot into recovery and flash the ROM. Don't worry, you have a recovery so you are not bricked at all, just need a ROM. Make sure it's a stable and custom ROM, eg CyanogenMod.
Sent from my LS670 using Android Central Forums
Please Help....
You cant brick your Gnexus unless you did some serious hardware damage. this means you dont know what to do next.
do a factory image restore http://forums.androidcentral.com/ge...er-factory-restore-root-any-nexus-device.html
I think why I am having issues is ADB and Fastboot give me errors when I try to connect. I have used many different cords, usb outlets, and drivers and still cannot push a file to my sd card.
websitedesig88
