Help me fix my puzzle piece problem!
After following the link to the ROM you used there is a correction for at the bottow of the post to correct the puzzle lock issue
I believe the thing at the bottom was simply adding the puzzle lock screen to the system, not fixing the problem of the message puzzle piece not showing up, which I'm experiencing as well. It'd be nice to get the message piece back, but overall, I don't miss it enough to spend too much time tracking down the cause.
Yeah, it's not a huge deal but it does get annoying..
Still needing a fix
I'd still like to find a fix to this... I do use Handscent and SMS pop-up but that shouldn't have affected my SMS puzzle piece indicator...
Thanks!
amgd73600
