Help my phone keeps resetting Its self
dman7895
4
My phone will not stay on at all. It will keep restarting unless plugged up to a charger or computer. It will just keep doing that every five seconds I have a galaxy s2 skyrocket
that's strange. i would make sure everything is backed up and then i would do a factory reset and start from scratch. good luck.
I've done that and it keeps restarting
It's worth clarifying if you did an actual factory data reset, or simply a soft reboot.
Also, consider trying a different battery.
Sounds pretty messed up. Can you try a different battery?
One thing that could have happened ( if you have perhaps dropped your phone ...) is that the battery is looe and keeps slipping off .. in that case maybe try to put to put a little piece of cardboard on the side to secure the battery so that its real tight ?
simizen0611
