A
AC Question
A couple hours ago my phone fell off my bed about a 4 foot drop, it was nothing new since my phone had a case and would sometimes fall on the ground but would be perfectly fine. Later I noticed the phone was off which was weird since i never turned it off and it was at 94% of battery life last time I checked, I try turning it on but to no avail. I start getting agitated and plug it into a charger, the battery and the lightning bolt show up like normal and the battery fills up and says 94% battery life, I try turning it on while on the charger and it works, but about not even a minute later it turns off, I turn it back on multiple times while on the charger with the same result, the phone shutting down after about 30 seconds, when I unplug the phone it won't even turn on. I ave already tried putting it in recovery mode and hard resetting the phone but it doesn't work. Can anybody help me?
