Help, My settings menu wont open!
youngSWi
Active member
Apr 20, 2011
39
For some reason today, my optimus v stopped opening the settings menu... it just flashes open then closes. I cant access any settings options! :( HELP PLZ
Well playing around with it, it appears that QuickSettings is making me unable to open the settings, I can open it before quicksettings launches, but it closes when it does launch. How can I uninstall quicksettings without the settings menu?
You can't uninstall your original settings menu. Just uninstall quicksettings if you're havin issues.
Well to uninstall quicksettings, i have to be able to access my settings menu.... I got quicksettings uninstalled so i think its penetrate pro causing issues now
not penetrate... now trying router keygen, if this doesnt work ima recover from the stock recovery
DannaOgle83
