Help need with connect to computer
A few tips for this that I've come across:
  1. Try a different cable.
  2. Try a different USB port.
  3. Uninstall then re-install the drivers.
  4. Go into "Device Manager" if using Windows 8 and find the Samsung device. You can 'fix problem' from there. If you're using Windows 7, you can go into Start > right click Computer > Properties.
I also have the problem that my phone is not detecting by any computer, and can't sync vie USB
- Have you installed the Samsung USB drivers?
- Are you using the USB cable that came with the phone?
- Do you see the "installing hardware" prompt when the phone is connected to the PC?
958ryan
